Author: Subject: Anyone used the Zetec and all ancillaries?
cjwood23
posted on 3/2/12 at 11:39 AM Reply With Quote
With the abundance of Zetec's on ebay being sold with ECU, EFI and all the other gubbins has anyone managed to use all of it?
I know most can't fit under the bonnet because of the plenum chamber, but with the new offering from Bogg Bros allowing injectors etc. to be re-used with their plenum it's got to be a cheaper alternative than TB's, Carb and new management?
Has anyone managed to use the zetec ECU? WIth a piggy-back chip you could remap and have a fairly healthy output.
Thoughts?
______________________
Chris
loggyboy
posted on 3/2/12 at 12:40 PM Reply With Quote
pretty sure big_wasa has done alot on getting standard ECUs working. When I collected my kit Raw told me that due to the shape of the strikers bonnet you can fit the standard plenum on their kits, so im sure a bonnet bulge would allow other style 7's to fit it.
AndyW
posted on 3/2/12 at 12:55 PM Reply With Quote
I have used all of the original ecu, pats etc. I used a plenum chamber from GBS which is about £200 and have full working injection, ford immobiliser and OBD.
So the answer to the question is yes, it can be done!!
Link to start up video
garybee
posted on 3/2/12 at 12:56 PM Reply With Quote
Plenty of people on here have done this with the later (EECV) ecu. I've used the earlier (EECIV) ECU, you can buy inlet plenums that use the standard injectors/throttle body if the original plenum is too tall (probably will be for most people). GBS make a neat plenum that I bought a few months back.
cjwood23
posted on 3/2/12 at 01:52 PM Reply With Quote
Cheers chaps!
Didn't realise GBS did one too - and cheaper than BB's.
Thanks again.
Chris
posted on 3/2/12 at 02:04 PM Reply With Quote
Originally posted by cjwood23
Cheers chaps!
"Cheap" is likely to be the operative word if it's anything like the loose collection of tubes they have the audacity to call an exhaust manifold.
cjwood23
posted on 3/2/12 at 02:29 PM Reply With Quote
Do you need any additional bits and peices to make it work? or does it use the standard injector rail etc.?
Chris
loggyboy
posted on 3/2/12 at 02:38 PM Reply With Quote
Cheers chaps!
Looks quite well made to be fair:
http://www.kitspares.co.uk/shop/item.php?cat=6&product=8958&catsub=0
Not cheap tho, and needs some sort of modified injector rail, so hardly an 'all in one' solution. Its the mounting costs like these that pushed me towards the complete weber alpha kit (allthough i dont think I would have paid full price for one).
[Edited on 3/2/12 by loggyboy]
femster87
posted on 3/2/12 at 03:05 PM Reply With Quote
Cheers chaps!
The Mounting is pretty straight forward to be honest. You chop the plastic flange off the original inlet this has the injector bosses pre moulded in them. Bolt this on and you can use the original rail unmodified
cjwood23
posted on 3/2/12 at 03:59 PM Reply With Quote
Thanks again guys.
Another question though.
What have you done about the cats when using the standard ECU set up?
Chris
big_wasa
posted on 3/2/12 at 06:35 PM Reply With Quote
mine
I use mondeo donors for most of what I do due to easy availability of parts and the engine loom is almost self contained. These upto 2000 ish dont have post cats or post cat lambda sensors.
So run with or with out.
Its an easy Iva pass on emissions if you use a cat.
Ive had a brief look at piggyback ecu's
Will fit a piggy back chip when I find one for good money.
[Edited on 3/2/12 by big_wasa]
cjwood23
posted on 10/2/12 at 08:55 PM Reply With Quote
Originally posted by big_wasa
mine
Cheers Wasa, thanks for the info.
When did they start using 'fly by wire' throttles? - I'm guessing his could be a bit of an issue with using an after market pedal box?
What about the 1.7 from the Puma? Is that badged as a 'sigma'?
Chris
Chris
