andyharding
| posted on 20/8/04 at 06:31 PM |
Zetec to Type 9 Starter Motor
As I've spent the last few days trying to find a starter motor I thought I'd share my success.
I have fitted a Type 9 gearbox to a '94 1.8 Zetec with an Escort sump.
I've used a starter motor from a CVH 1.8 Sierra. £59 from Cargo.
I've had to sand 3 of the ribs flush with the sump to get it to fit but the pinion and throw are spot on.
  CVH 1.8 Starter Motor
Mal
| posted on 20/8/04 at 09:16 PM |
Zetec to Type 9 Clutch
Andy,
I am going to use a Zetec and Type 9 combination and was pleased to see the results of your efforts and advice.
If you have already fitted the clutch and release mechanism can you advise on the parts needed for this please?
I shall be using cable operation.
Mal.
dave1888
| posted on 20/8/04 at 10:13 PM |
Andy I see from your photo that you have blocked of the crakcase breather, what have you done as a replacement breather vent
andyharding
| posted on 21/8/04 at 06:37 PM |
Mal:
I haven't done the clutch yet - that's next on the list. I'm going to use a Dunnel flywheel as it's only 6KG. It may be
possible to fit a CVH cover and plate to the Zetec flywheel. Don't use the standard ones even though the splines are right. The fingers are the
wrong length. I'll post again when I've sorted the clutch.
Dave1888:
I'm going to weld a breather pipe into the plate. I haven't done yet as I'm still cleaning the block and it will stop cack getting
in. Again, I'll post again when I've finished this.
FatChapChipChop
| posted on 24/8/04 at 02:21 PM |
If you use a Dunnell flywheel it's simply a lightened Zetec original item .. and good it is .. you can use the Zetec cover plate but use a
clutch plate from a Capri V6. You will also find the clutch face is around 12mm closer to the block compared to a Pinto flywheel so you need a deeper
clutch release bearing .. QH133 is the part number .. This keeps the fork well back which is better for correct pivot operation .. otherwise, you go
past the horixontal point and it gets mechanically more difficult to depress the clutch.
Drive fast, don't look back!
rocket
| posted on 12/10/04 at 07:30 PM |
well I cracked on today!
This is what I've done so far.
I've got a 2litre zetec with 1.8 escort sump/water pump.
I've used the escort flywheel and pressure plate. The cvh doesn't fit on the pegs ( bigger) The escort flywheel is smaller and lighter
than the 2l mondeo.
But the splines on the clutch don't match my input shaft! The clutch for the 2l do but that won't go ( to big) but the cvh cluth plate
fits!
So I've got flywheel from 1.8 and pressure plate from 1.8 but clutch plates from cvh.
The dust cover from a cvh sierra fits with a slight mod. as does the starter motor.
So in theory I'm there just need to see if clutch releases ok.
Roger www.shinybitz.co.uk
RobC
| posted on 9/1/05 at 07:49 PM |
I am doing a similat install 2.0 onto t9... But... Having real diffuculty getting the crankshaft and flywheel off? Anyone got any ideas
stevebubs
| posted on 9/1/05 at 08:30 PM |
code: I've used a starter motor from a CVH 1.8 Sierra. £59 from Cargo
Cargo? Can you provide details?
RobC
| posted on 12/1/05 at 08:20 PM |
btt can anyone help answer mine and the other chaps question?
[Edited on 12/1/05 by RobC]
stevebubs
| posted on 12/1/05 at 08:39 PM |
Crank Shaft AND Flywheel?
Surely you me Flywheel off the Crankshaft?
Have to ask the idiot question first (hopefully you won't take offence)
You *have* undone the 6 bolts holding the flywheel on, haven't you?
If not, this can be difficult, and I found a good solution was
put a couple of long bolts through in the clutch cover mountings
put engine on the floor
Using a long piece of metal bar between the bolts to hold the flywheel in position, undo the flywheel-crank bolts with the longest breaker bar you
can find.
Not ideal as you're putting load on a couple of things that shouldn't really be loaded but I've used it several times without
incident.
If you have undone the bolts and it won't come off, spray it with penetrating oil and bash the flywheel with a soft rubber mallet.
RobC
| posted on 12/1/05 at 10:16 PM |
many thanks, and yes the bolt won't budge... thanks for the tip, I'll give it a go tomorrow evening.
Many thanks once again
RobC
| posted on 16/1/05 at 08:28 PM |
how is Cargo? Can anyone give us details?
many thanks
[Edited on 16/1/05 by RobC]
