Author: Subject: quafie gears
metro6r4
posted on 10/2/12 at 09:48 PM Reply With Quote
quafie gears
hi has anyone got any advice on picking a set of gear ratios to use for drag racing, the box im using is a ford type 9. Im planning on putting between 220hp and up to a max of about 280hp i know im going to fit a quafie gear set the car will weigh in at about 650kg and wont be used on the road i have a budget of about £1200
has anyone used firstmotion transmsions or road and race transmisions in seven oaks any opinions or recomendations would be apreciated
snakebelly
posted on 10/2/12 at 10:36 PM Reply With Quote
Used road and race a couple of times, very helpful and did good work for me
ajw
posted on 10/2/12 at 10:44 PM Reply With Quote
The dog engagment gearset is the way to go, also lightweight casing. If you searched you could pick up a 26g quaife seq box as they are now surpassed by 60g and have dropped in value. I sold a Quaife alloy dogbox last year for £2200 .
Chippy
posted on 10/2/12 at 11:03 PM Reply With Quote
Another vote for Road and Race Transmissions, very helpful guys. HTH Ray
purdy
posted on 11/2/12 at 08:55 AM Reply With Quote
Have a look at tran x I'm running a 4speed dogbox type E same as the type 9 just 4 speed, I think there gear kits are around 700. My 2.3 duratec is turning out
277 Bhp and 220 ft lb torque. Give me a call if you need any specs ie ratios speeds tyre sizes etc.
Chow
Mark
07514 138 806
