mackie
| posted on 22/8/04 at 02:56 PM |
What's this bit do? (Rover V8 EFI)
What's the arrowed thing do? Our plenum has the machined bit to which it fits but the hole is plugged with a coreplug and the bolt holes
aren't drilled.
Engine runs fine and there are no hoses or wires left unconnected so I assume it's nothing terribly important, I just think it odd that it
doesn't have it when pretty much every similar engine I've seen has.
twinturbo
| posted on 22/8/04 at 05:20 PM |
Difficult to tell, but looks like it may be an Idles speed control valve, you may have an early plenum that had a seperate valve fitted..
Only a guess mind.
TT
Donners90
| posted on 22/8/04 at 05:22 PM |
bypass valve
Taken from LR manuals
HTH
James
twinturbo
| posted on 22/8/04 at 06:55 PM |
Idle speed controle valve then ( puts on smug grin )
TT
blueshift
| posted on 22/8/04 at 10:30 PM |
Don't remember that on the wiring diagrams when I wired it up. maybe it's a hot wire EFI only thing, ours is flapper
mackie
| posted on 22/8/04 at 10:42 PM |
Engine in the picture is a 3.5 SD1 Vitesse engine I believe, hench why I asked.
If that is an idle control valve (the diagram is for a hotwire 3.9) then I assume our engine just does without.
twinturbo
| posted on 23/8/04 at 08:15 AM |
Hot wire or not it should still have an idle valve of some description.
TT
mackie
| posted on 23/8/04 at 08:26 AM |
You'd certainly think so but it idles fine. Or at least I think it does, it's a bit difficult to tell how lumpy it is without exhausts on
and no tacho hooked up.
