Mark Allanson
| posted on 22/8/04 at 09:40 PM |
Pinto plumbing again
Now I have sorted out where all the hoses should go, and now fitted them all, I am very pleased with them all except the bottom rad to pump. I have a
book chassis and cannot find a route for the hose where it does not touch the chassis at some point.
How have you done it?
| posted on 22/8/04 at 09:44 PM |
mine touches the chassis in several places, and thats with a few feet of space to play with! i'll check for chaffing regularily, aside from that
it should be ok.
Mark Allanson
| posted on 22/8/04 at 10:08 PM |
I'm not sure what the SVA position is regarding hoses, I might make up some bit stainless P clips to make it look like I intended them that
way!
James
| posted on 22/8/04 at 11:09 PM |
Hmmm, Mark that engine bay looks familiar! I'm doing the same bit with mine now.
Mine touches the steering rack where it comes over it- don't know how else to protect it.
In terms of SVA- if touching the chassis any worse than touching the inside of a 'P' clip?
James
P.S. How'd you do that massive 'P' clip?
bob
| posted on 23/8/04 at 07:52 AM |
My bottom hose touches the chassis at the 90 deg bend then touches the steeering rack where it goes inbetween rack and chassis.
I had the missfortune of having my SVA when the guy testing my car was being examined by the area inspector neither made anything of it touching
anywhere.
DaveFJ
| posted on 23/8/04 at 08:14 AM |
how about welding on a small curved piece of metal ( maybe a bit of steel tubing cut in half along it's length ) - If you follow my drift!
this would effectively cup the hose and should prevent chaffing
Dave
