HowardB
posted on 19/2/12 at 06:34 PM |
cable clutch in RS2000 bellhousing - HELP please
I have an RS2000 aluminium bellhousing for my Zetec and rather than change to hydraulic clutch I need a bracket to fit the cable. Retroford do one,
but I want to incorporate the hole into the existing cover plate.
This is the retroford one,..
[img]
[/img], any one got one that they can take the dimensions from so I can work out where to put the hole?
many thanks in advance
Howard
scutter
posted on 19/2/12 at 07:24 PM |
Sorry I don't have the diamentions, But when you say the existing cover, are you taking about the dirt shield?
The retro ford one will be 6-8mm thick to stop you pulling the cable through. I don't think the dirtshield is thick enough.
ATB Dan.
HowardB
posted on 19/2/12 at 07:54 PM |
thanks for the Dan, I have a dirtshield that is thick aluminium,.. 5mm so I thoght that would work,.. Perhaps someone will have one hidden in a box
somewhere
thanks again
Howard
scutter
posted on 20/2/12 at 02:47 PM |
I've an old steel bellhousing somewhere, I'll see if I can find it and take some measurements
ATB Dan.
HowardB
posted on 20/2/12 at 03:52 PM |
thanks for that,.. appreciate the help
Howard
