makoto
posted on 3/3/12 at 02:08 PM |
Which radiator - 4age
Hi folks ,
Ive got a bike radiator which I am thinking of using on my 4age engine
This is due to the space available.Will this provide enough cooling for the engine or do I need a bigger one?
loggyboy
posted on 3/3/12 at 05:26 PM |
Cant see a bike rad managing, bikes rely on alot of air cooling as well as water.
Standard is to use one of these:
VOLKSWAGEN POLO 1983-1990 / DERBY / SEAT TERRA RADIATOR NEW - 2 YEAR WARRANTY | eBay
They are quite narrow and go in well in the nose of a '7'.
As all the pipes are on the left so means neat plumbing on the same side of the car the engine outlets are on, just needs a long pipe along the side
of the engine bay.
[Edited on 3/3/12 by loggyboy]
bi22le
posted on 3/3/12 at 06:30 PM |
Loggyboy is that your old car?
What air filter\ plenum set up are you using?
Supercharger?
Please read my ring story:
maccmike
posted on 3/3/12 at 07:30 PM |
Hi mate, I run a zzr1100 in the back of my trike, gets very little air flow if any. due to packaging probs like you, my rad is about 3/4 the size the
bikes got. i also run the standard and original oil cooler. Iv fitted each with a fan, wired together into the rad fan switch. when coolant comes up
to 91 degrees, both fans come on. due to smaller rad fans are on more frequent and for a split second longer. works a treat though. so yeah go for
it, itll be fine, especially if you can an oil cooler which are tiny so should find a slot for it somwhere
loggyboy
posted on 3/3/12 at 07:44 PM |
What air filter plenum set up are you using?
Supercharger?
No not mine, thats the (old?) Raw Demo car. It was supercharged though.
