Author: Subject: best way to fit a single point fuel injection system to a petrol landy 2.25
Mr Whippy
posted on 5/3/12 at 07:00 PM Reply With Quote
Hi
I have a 2.25 petrol landy that I was thinking it would be nice to fit a single point injection system to and a lamda sensor so I had close loop mixture control
The carb is just rubbish and the manual coke a pita
Any reasonably priced systems around these days I could retrofit? can't see an engine any more simple to modify than a basic landy one
I remember mega squirt system but not sure that even exists now
cheers )
minitici
posted on 5/3/12 at 07:20 PM Reply With Quote
Was thinking the same for my Series IIa.
There are lots of single point injection units on a well known auction site.
A simple manifold adaptor might suit.
Certainly stands a better chance of getting some fuel economy compared to a worn out 40 year old Solex or Zenith
posted on 5/3/12 at 07:41 PM Reply With Quote
I suspect this could give quite a reasonable improvement in economy and driveability in an old Landy, especially if combined with ignition control.
You might even find a suitable SPI throttle body from an older car that will fit the Solex/Zenith manifold, or a simple adapter plate could be made. You'd need to find something from a car with similar power to your Landy, maybe a 1.6 8v Astra like this: Throttle Body Vauxhall Astra X16SZR 1.6 8v MK4 1998-2000 | eBay
This part includes the throttle, the injector, fuel pressure regulator and throttle position sensor so would solve a lot of problems in one go.
Megasquirt is still around and the majority of aftermarket systems should be able to cope with a simple SPI system.
Mr Whippy
posted on 7/3/12 at 12:21 PM Reply With Quote
Thanks I'll look into that
It's more to improve drivabilty especially when cold, I have a newish carb and it runs rather pathetic
posted on 7/3/12 at 01:01 PM Reply With Quote
ISTR most single point systems depend on electric manifold heaters to improve mixture distribution, it might be worth looking at the throttle body from a SPi Metro early 90s Rover 214 Spi or the early Rover 820i. spi.
However if I had a petrol Landy I would go straight fo an LPG conversion and almost half fuel costs.
