loughlin1
posted on 8/3/12 at 10:45 PM |
starter/altanator cable
Hi aLL
lights all going now ,that is that finished,onto the cable from the starter to the altanator and where it comes from, if i am correct i take the same
size of cable that is on the poss side of the battery and route it down to the starter then what ,does the same cable go from the starter to the
altanator .
austin man
posted on 8/3/12 at 11:04 PM |
The cable from alternator to battery / starter doesn't need to be as big I think mine has a 20 amp cable
[Edited on 8/3/12 by austin man]
loughlin1
posted on 8/3/12 at 11:49 PM |
what size of cable is it ,i have seen 12v 20amp cable but it is 2 core is that the wire i need and if so where does the second wire go to
posted on 9/3/12 at 07:10 AM |
Depends on the rating of the alternator which is generally in the range 17 for a Cortina to 90 amps for a Mondeo diesel.
loughlin1
posted on 9/3/12 at 07:18 AM |
2lt pinto engine
cliftyhanger
posted on 9/3/12 at 07:34 AM |
You need to match the alternator cable to the alternator, or rather exceed it a little.
So if you have a 40A alternator, use 40A plus cable. Best to allow for future changes too, although it isn't difficult to add extra wiring if
needed at a later date.
loughlin1
posted on 9/3/12 at 08:29 AM |
great many thanks for the help
posted on 9/3/12 at 06:08 PM |
You can use both large connectors on the alternator.
