hootsno1
| posted on 12/3/12 at 08:05 PM |
mt75 mated to 2.0 duratec
Evening all
Just thought i would post a pic of mt75 gearbox mated to a 2.0 duratec
  mt75 mated to duratec
If a little hammer won't fix it get a bigger hammer
sebastiaan
| posted on 12/3/12 at 08:08 PM |
Is this a transit box?
hootsno1
| posted on 12/3/12 at 08:12 PM |
The front bell housing is from a 2.3 log duratec transit the rear part is from a sierra mt75 as i could not find a compleat box.
pjay
| posted on 12/3/12 at 10:11 PM |
Looks good. Is it just my eyesight or does it put the engine over slightly like on the Mazdas (10*)?
vanepico
| posted on 12/3/12 at 11:27 PM |
How did you get it looking so new?!
hootsno1
| posted on 13/3/12 at 06:08 AM |
I cleaned it with gunk and a wire wire cup in a drill the used a die grinder to do all the nooks and crannys then wash down with meths and primed and
painted it with ally hi temp paint I'm not happy with the front casing and rocker cover so they will be coming off to be shot blasted and powder
coated
Andrew Eales
| posted on 21/7/14 at 08:46 PM |
What flywheel and clutch did you end up using ? and did you need a spacer ?
I am in the process of having a hybrid MT75 box made using my existing sierra MT75 and the front end of a transit diesel MT75.
Could have problems with the starter as it doesn't have the correct size hole in it !
