Author: Subject: x flow cam followers
myke pocock
posted on 14/3/12 at 09:24 PM Reply With Quote
Set of cam followers for a x flow are £78:00 from Burton Power and £29:99 off ebay. All I will be using them for is road work so not consistent high revs. Anyone got any experience of the ebay followers?
arrow-engineering
posted on 14/3/12 at 10:06 PM Reply With Quote
most things at burtons are top prices!
my brother has those followers in his crossflow road car, no problems 2 or 3 years later, and ive just fitted a fully recon engine with the same followers, no issues here.
i had my doubts, but so far so good
jollygreengiant
posted on 15/3/12 at 11:13 AM Reply With Quote
Just make sure they are the right diameter on the shaft. Early ones have a narrower diameter than the later ones. If you 'accidentally fit the early ones on a later block (thanks to SHELLTUNE, NORTHAMPTON) then your engine will sound like a rattly old sewing machine and the mushroom heads will fall/break off at about 750 miles, usually snapping the cam shaft as well, IF you are lucky it will snap in front of the distributor/oil pump drive gear.
DON'T ask how I know as that was 31 years ago.
edit bit
Oh and the later ones will NOT fit in an early block.
[Edited on 15/3/12 by jollygreengiant]
posted on 15/3/12 at 07:44 PM Reply With Quote
I managed to get a Kent BCF2 cam kit complete with cam followers for less than the Burton followers from Ebay
arrow-engineering
posted on 15/3/12 at 09:15 PM Reply With Quote
there has been an issue with the kent followers, they had a batch that wore out very quickly, the material was just not up to scratch, it ruined cams and spoilt a lot of peoples days.
be careful as there may still be some of these duff followers kicking about. they never did a recall or officially admitted a problem.
