Author: Subject: couple of blade questions !!
tompat3463
posted on 19/3/12 at 06:08 PM Reply With Quote
ive got a complete fireblade engine ready for an install however some of the parts are from different bikes as I've just aquired them from ebay and the like over the winter and last year..
so my questions are
1.
If my TB's dont have a TPS and my blade engiine loom has a TPS plug will this loom be suitable for the engine ??
2.
Can any body advise what size HEX bolts are required that bolt the stator into the stator cover ??
thanks in advance Alan
MK9R
posted on 19/3/12 at 06:26 PM Reply With Quote
What blade is it? The carb blades dont need TPS connected
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
tompat3463
posted on 19/3/12 at 06:51 PM Reply With Quote
the block is a 893.. the olderst one.
the carbs are from the same year engine as is the CDI but the loom is newer I think as it has TPS plug on it !
MK9R
posted on 19/3/12 at 07:02 PM Reply With Quote
Ok no need for TPS then. Cant help on bolt size though ,)
Cheers Austen
RGB car number 9
www.trackace.co.uk
Andy B
posted on 19/3/12 at 08:26 PM Reply With Quote
Send me an address and I will send you some stator bolts 6mm but cant remember the length off the top of my head
regards
