jarnom
posted on 22/3/12 at 10:40 AM |
Audi 01X shift pattern
I'm using the 01X box but I'm not sure on how the shifting pattern works on the box itself.
I believe that when you pull out the shaft on the box, and rotate it clockwise (seen from the left side so it rotates towards the rear) it should be
in 1st, to the front 2nd, 3rd and 4th halfway and 5th and 6th pushed all the way in, is this correct?
Reverse should be when you pull the shaft all the way out, right?
If you look inside the car reverse is on the left side next to 1st gear.
I found some pdf file about different audi boxes but it also says the patterns are all different for the 01E, 01X, 0A3 etc., so need to know for this
one specifically.
Thanks in advance.
coyoteboy
posted on 22/3/12 at 10:59 AM |
Sorry, I don't have that info and I only have an 01E, but isn't it easy enough to figure out? Move it through all locations and turn the
input shaft counting turns in and out. A bit laborious but easy enough.
jarnom
posted on 22/3/12 at 11:01 AM |
Why didnt I think of that I will give it a try thank you.
