Author: Subject: Engine out
rost
posted on 29/3/12 at 07:13 AM Reply With Quote
Engine out
And found the problem:
It's a 190mm clutch on the 212mm face on the flywheel, so a bit sub-optimal Didn't pay enough attention when I assembled it, guess my supplier here in Holland didn't really think it through.
Also, the release bearing failed again! I must be doing something wrong. Are you using the standard T9 release bearing, or is there an uprated one somewhere? I'ts a 4A-GE engine to a T9 gearbox btw.
Charlie don't surf!
HowardB
posted on 29/3/12 at 08:24 AM Reply With Quote
time to invest in an AP clutch,.. much better,...
Howard
posted on 29/3/12 at 08:31 AM Reply With Quote
I've seen numerous standard clutches on normal road cars fail in the same way, so it's not necessarily due to your set up. Is the friction plate a decent branded part (Valeo, Luk, Borg and Beck etc) or a cheaper part?
In what way did the release bearing fail? Are you using a Ford cover, or a Toyota part?
rost
posted on 29/3/12 at 09:00 AM Reply With Quote
It's a Luk plate. I'm not sure about the cover.
My previous bearing failed with a terrible rattle, but this one is even worse: I can jiggle the bearing part about 5mm while the bearing's plastic center shaft stays put.
I've got a new Helix cover and plate, but I'm still unsure about the release bearing, don't want it to fail again.
Charlie don't surf!
snapper
posted on 29/3/12 at 11:27 AM Reply With Quote
Round fingers on the clutch cover uses flat release bearing, flat fingers on the cover uses a rounded at the edges bearing
Look at the real ease bearing for the clutch cover and compare with Ford release bearings.
I eat to survive
I drink to forget
bi22le
posted on 29/3/12 at 11:43 AM Reply With Quote
I have never dismatled that area of my car but I am sure on the spec sheet I got the previous owner to right up he stated that he fitted two release bearings as there was space.
It is a 4age Blacktop to type 9.
Please read my ring story:
rost
posted on 29/3/12 at 11:49 AM Reply With Quote
The OEM one does have a slightly beveled edge, the stock T9 one has a flat face. I can't really find one with a rounded edge, do you know of any suppliers?
This is a std. 4AGE one:
Charlie don't surf!
