doddy
posted on 30/3/12 at 06:43 PM |
can i fit this sump on a black top zetec
hi im after a lower sump for my blacktop zetec can afford a raceline one so will this do it from a silvertop escort si as it will give me more
clearance but do i need the splash plate or any other parts cheers doddy
eBay - The UK's Online Marketplace
[Edited on 30/3/12 by doddy]
https://www.ebay.co.uk/str/4x4wheels
big_wasa
posted on 30/3/12 at 06:57 PM |
Yeh you will either need four 20mm spacers and the main cap bolts from a silver top to re space the windage tray from the crank or spacers to space
the tray form the sump.
edit.
its not going to give you much clearance over the black top.
You may have to grind the side of the sump to get clearance for the starter.
[Edited on 30/3/12 by big_wasa]
doddy
posted on 30/3/12 at 07:52 PM |
ok thats great i will look into getting some silver top bolts cheers ian
Dusty
posted on 30/3/12 at 11:22 PM |
The main cap bolts you need are from 2 and 4 main bearing. I will put a pic in my archive as they are a double ended bolt.
doddy
posted on 31/3/12 at 06:24 PM |
rthanks for the picture does any one no the part number and any idea of price from ford im going there on monday see if they can get them for me i
take it i need 4 studs and nuts
