Author: Subject: Zetec Blacktop won't start
ChrisL
posted on 30/3/12 at 08:41 PM Reply With Quote
The continuing saga of by 1.8 ST to 2.0 BT Zetec swap.
Tried starting the engine - no joy. Engine turns over fine, got spark and fuel and I think the crank angle sensor is correct, from the plug side it looks the same as the old one. I've got a megajolt map taken from a car with the same set up. Fuel is about a month old. All the ancillaries worked fine on the 1.8 ST, except one of the carbs (#3) leaked so the carbs have been cleaned, float valves adjusted. I don't think this has fixed the leak but this should stop the engine starting. (will get carb refurb kit tomorrow). So any ideas what to check next....?
Cheers and thanks
Chris
doddy
posted on 30/3/12 at 08:52 PM Reply With Quote
make sure you have the crank angle sensor wires on the right way round
https://www.ebay.co.uk/str/4x4wheels
matt_gsxr
posted on 30/3/12 at 08:56 PM Reply With Quote
What is it doing?
Just cranking not a hint of starting?
Coughing?
Backfiring?
monck
posted on 30/3/12 at 09:13 PM Reply With Quote
Cant help but your not the only one having trouble
ChrisL
posted on 30/3/12 at 10:17 PM Reply With Quote
Good to know!!
Just cranking with no hint of a start but the starter does disengage like it's starting but not getting a bang!
FazerBob
posted on 30/3/12 at 10:36 PM Reply With Quote
try starting for about 15 secs, then whip out a couple of the plugs, and check if they are wet, or smell strongly of petrol. If they are dry start looking for a fuelling fault. If they're wet you aren't getting a spark, so look for ignition faults.
matt_gsxr
posted on 30/3/12 at 11:08 PM Reply With Quote
FazerBob is right.
If it turning over properly and isn't coughing of anything then there are only 4 sources for the problem:
1) no fuel (whilst cranking)
2) no spark (whilst cranking)
3) spark at wrong time
4) no compression
to test
1) Fazer Bob test, or spray some Eazistart
2) Sparks can be tricky as when the plugs are out it can be easy to get a spark which can fool you into thinking it works. A timing light (with inductive sensor) is a good test that allows the plug to be left in the engine.
4) Compression test (make sure throttles are open).
Spark at wrong time normally give back-fires, but not necessarily. Similarly timing light will provide the clue as to whether spark is at the right time.
Good luck and get that battery on charge.
Matt
ashg
posted on 31/3/12 at 12:25 AM Reply With Quote
even if the spark was at the wrong time you would get a bit of a splutter now and then.
check the crank sensor wires fuel/air/spark. do you have a timing light?
with your engine at tdc on no1 cyl your sensor should be 90degrees behind the missing tooth like this
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
ChrisL
posted on 31/3/12 at 06:56 AM Reply With Quote
Cheers for the advice guys. I'm pretty sure I'm getting fuel, so I'll dig out my timing light and see what that shows...
posted on 31/3/12 at 07:09 AM Reply With Quote
Try a squirt of brake cleaner down the inlet while cranking with a little bit of throttle , if the ignition side of things is OK it should fire up and run at least for a few seconds
RichardK
posted on 31/3/12 at 01:11 PM Reply With Quote
Do you know if the zetec was from an auto boxed car,if it was the housing of the crank position sensor needs changing for a manual housing,are you using the back of the flywheel for timing or a toothed wheel like Ash?
My advice would only apply if using the normal crank pos sensor and flywheel.
Rich
Gallery updated 11/01/2011
RichardK
posted on 31/3/12 at 01:19 PM Reply With Quote
Picture from my gallery
Rich
ChrisL
posted on 31/3/12 at 06:59 PM Reply With Quote
Pretty sure it's not from an auto as the flywheel bolts were too long for a 1.8 flywheel (on a 2.0 engine) the auto ones are short enough. also the Crankshaft angle sensor looks the same, from the plug end.
If it is an auto sensor, what effect would that have on the spark timing?
ChrisL
posted on 31/3/12 at 10:02 PM Reply With Quote
Result, got her started, seems the fuelling isn't quite right, yet. Seems I wasn't being brave enough with the throttle!! Oh well we live and learn.
Many thanks for all the advice / help.
Cheers Chris
RichardK
posted on 1/4/12 at 07:50 AM Reply With Quote
Glad you got it sorted, but for the benefit of others, the sensor is the same, it's just the housing that makes it point further in and in a slightly different place.
Rich
