itsawindupuk
| posted on 31/3/12 at 02:22 PM |
duratec to type 9 sudden noise, the result!
hi guys, firstly a big thanks to everyone on the forum who has helped me out. Today i took the gearbox out and found out what caused the horrid noise.
I used a spacer kit as im using a v6 gearbox, and the supplied bolts have come loose. Looking at it closer i can see the bolts dont come right through
the threads on the gearbox even though they are the longer ones. Anyone know where i can get even longer ones? Need to be about 10mm longer than the
ones retro ford supply.
Adam
[img]
  no bolts
[/img]
big-vee-twin
| posted on 31/3/12 at 02:29 PM |
I got some long ones from Namrick on the net think they are 12 x 1.5mm.
Glad to hear it may not be too serious, check for the bell housing bolt when you open it up though
http://www.triangleltd.com
itsawindupuk
| posted on 31/3/12 at 02:42 PM |
i did, ive had it all apart and there is no damage to clutch or bell housing, or slave. Quite lucky really.
big-vee-twin
| posted on 31/3/12 at 05:47 PM |
That's great news
redeye
| posted on 31/3/12 at 06:07 PM |
Great news
Looks like nothing major and an easy fix.
Stott
| posted on 31/3/12 at 07:38 PM |
Measure the bolts and post here what you need, I might have some in the garage, either hex or allen head as I have a lot of long M12 metric coarse
stuff
itsawindupuk
| posted on 1/4/12 at 10:56 AM |
thanks, i think they are fine thread as there m12 x 1.5, stuff in b and q are 1.75 i think. Im after some at least 70mm long.
Adam
| posted on 1/4/12 at 10:59 AM |
A little drop of threadlocker would help as well..
No local fastener suppliers?
