Author: Subject: Bike carbs -what to lookout for?
makoto
posted on 9/4/12 at 07:08 PM Reply With Quote
Hi ,
I am hoping to buy a set of bike carbs for my 4age
Engine?what do I need to lookout for when purchasing?
If any body have a set or know where I can get a set cheap
please let me know.
austin man
posted on 9/4/12 at 08:09 PM Reply With Quote
The ZX 6 and 9r range seem popular I have the ZX9's and have had no problems
tul214
posted on 9/4/12 at 08:24 PM Reply With Quote
I used cbr600 fx carbs, look for some with a TPS fitted if you are running some sort of ecu.
1.6 Raw Super6 sold
makoto
posted on 9/4/12 at 09:16 PM Reply With Quote
Bike Carbs
Thanks for the replay. I want to get away from using an ECU at all. The challenge is that, I originally had a CVH set-up in the car and now replacing with 4age. So all wiring is cvh, so instead of the hassle of changing all the wiring with ecu etc, i was just going to use a bike carb to get away from the fuel injection etc. I do have a complete donor car. So any ideas on wiring workaround would be great
Autosri
posted on 9/4/12 at 10:05 PM Reply With Quote
how you gunna control the timing then
makoto
posted on 9/4/12 at 10:13 PM Reply With Quote
Hi Autosri,
What would the best approach be with this?
Autosri
posted on 9/4/12 at 10:21 PM Reply With Quote
I would think it has to be the megajolt ecu I don't think you will be able to fit a dizzy so gunna need some sort of ecu
makoto
posted on 9/4/12 at 10:36 PM Reply With Quote
I have got the standard 4age dizzy on now, are you saying that cant work with the bike carbs?
tul214
The 4a-ge came with a dizzy.
1.6 Raw Super6 sold
makoto
posted on 9/4/12 at 10:42 PM Reply With Quote
Also , where can I find the flange for the bike carbs on the 4age? Is there somebody on here who makes them?
tul214
posted on 9/4/12 at 10:46 PM Reply With Quote
Jason aka shorttrack123 on here made me the flange
laser cut 4A-GE inlet flange
I then made the runners and welded it all together. I used the old manifold to stop it twisting;
sprayed it up and re-spaced the carbs;
home made inlet
home made inlet
1.6 Raw Super6 sold
makoto
posted on 9/4/12 at 11:02 PM Reply With Quote
(tul214)Thanks for the info, really helpful. I noted you did not use the standard dizzy was this due to space? Also what would be your view on my wiring issue, whatts the best way forward. I have the original loom from the donor car , but would be allot of hassle to install etc?
Do you have any other pics of your engine set-up ?
tul214
posted on 9/4/12 at 11:11 PM Reply With Quote
..no, just that the engine came as a package from RAW with the OMEX ECU. Mine was one of the 1st they did and was badged as a '100'. It was a very simple 'spark only' system but was very reliable.
Re the wiring, the motor needs very little of the loom to run, I never had to look at the dizzy but I am sure that there will be some advice on here somewhere.
For pics, have a look in my archive
1.6 Raw Super6 sold
makoto
posted on 9/4/12 at 11:30 PM Reply With Quote
Thanks again. I found these on ebay , would they be suitable?
eBay - The UK's Online Marketplace
Cant find (shorttrack123) in member list but will check again.
makoto
posted on 9/4/12 at 11:31 PM Reply With Quote
Sorry, meant to say i added some pics to give you an idea of things.
Canada EH!
posted on 10/4/12 at 01:02 AM Reply With Quote
I bought a small electronic box from Australia for use with the standard dizzy as I am using 4 webers on my 4age. The ignition is set to running advance and the box retards the ignition for idle, used with a Lucas or Bosch sports coil.
tul214
posted on 10/4/12 at 08:11 AM Reply With Quote
Yes, they are the same as mine. Very simple to split and re-space. I just followed David's example here
I can't find shorttrack anymore either? he must have deleted his posts???
You could try FASTdan on here. He has a website here
1.6 Raw Super6 sold
whitestu
posted on 10/4/12 at 08:40 AM Reply With Quote
There are plenty of ZX6 carbs on ebay for less money. They will he job just as well. I have them on my 2.0 Zetec an they work really well.
Stu
tasmod
posted on 10/4/12 at 01:01 PM Reply With Quote
The 4age dizzy can't be used standalone.
It has the HV leadouts and the rotor arm but that's it. The rest internally is sensors for counting for the separate ignitor module plus Toyota ecu for spark timing. It's driven off the cam.
You would need either an ecu or Megajolt to run it.
Rob
makoto
posted on 10/4/12 at 06:58 PM Reply With Quote
Thanks folks. tul214, would you still have the drawing from which your flange was made? I haven't remove my TVIS yet, so cannot get a drawing from the head. I know there might be a different in ports, but hopefully might be the same as mine. The donor car is a 87 D-reg if that helps? If if not I will just have to get it off?
tul214
posted on 10/4/12 at 07:23 PM Reply With Quote
Probably not.....it was about 4 yrs ago
Mine was a small port engine from a corolla anyway.
You could just buy an inlet gasket to use as a template.
1.6 Raw Super6 sold
makoto
posted on 10/4/12 at 07:47 PM Reply With Quote
Ok. Thanks. Just on the carbs; from what year bike should the carbs ideally be?
makoto
posted on 17/4/12 at 09:19 PM Reply With Quote
All, thanks for all the help.I manage to get a set of cbr600 carbs
Now on to get the flange sorted.then getting the installation done.Will be back with an
An update.
