Author: Subject: Duratec Plumbing
laptoprob
posted on 10/4/12 at 08:39 PM Reply With Quote
Duratec Plumbing
I know its been done loads but cant find a good diagram of how to pipe up a Duratec.
Has anyone got one or can anyone point me in the right direction please?
http://www.youtube.com/watch?v=ajlF4nWJtGA
big-vee-twin
posted on 10/4/12 at 09:39 PM Reply With Quote
[img]
[/img]
http://www.triangleltd.com
hootsno1
posted on 10/4/12 at 09:40 PM Reply With Quote
If I have it right the the outlet from the nearside of the block goes to the bottom of the rad and the outlet from the head goes to the top of the rad.
GBS do a cheap top water rail and a outlet to replace the thermastat housing.
I have sent them some drawings for the rest of the water system to get them put into production, if you are not running a heater it will only need 3 38mm pipes and 5 silicon hoses and new thermostat housing similar to the Zetec one on there web site.
If a little hammer won't fix it get a bigger hammer
big-vee-twin
posted on 10/4/12 at 09:53 PM Reply With Quote
Do it much chaper by using a 38mm aluminium pipe and two sections of silicon for the top hose. I also used a couple of pipe brackets to secure the aluminium pipe to the top chassis rail
[img] Throttle bodies trial fitted
[/img]
laptoprob
posted on 11/4/12 at 06:54 AM Reply With Quote
Its actually for my brother but i think i understand the layout. He isnt running a heater at all so the pipe that runs to the heater should now go directly back to the thero housing i guess?
Also the `overflow` tank is the header, am i right?
big-vee-twin
posted on 11/4/12 at 08:07 AM Reply With Quote
Overflow is header, just blank off heater connections with a short piece of hose with a bung/bolt in the end.
redeye
posted on 11/4/12 at 10:37 AM Reply With Quote
Sorry to hijack
wheres the best place to buy the flexi silicone hose and 38mm alu pipe from?
Patrick
big-vee-twin
posted on 11/4/12 at 11:34 AM Reply With Quote
Off Ebay
neilp1
posted on 11/4/12 at 12:02 PM Reply With Quote
38mm pipe? I'm sure I've used 32mm ID for the silocone hoses and 32mm OD for the ali pipe!
laptoprob
posted on 11/4/12 at 01:59 PM Reply With Quote
Thanks for all your help
se7ensport
posted on 11/4/12 at 05:38 PM Reply With Quote
It's 32mm pipe and hoses you need.
