JP32
posted on 23/4/12 at 10:58 AM |
Cortina adjustable wishbone
Hello,
The question I have is simple, does anyone have a drawing from Cortina wishbone's? I just bought a Pilgrim Cobra with Cortina front suspension
and the camber and caster between left and the right front wheels are different. The origional wishbones from the Cortina are mounted (read: not
adjustable).
Or does anyone know where I can order adjustable wishbones, Cortina design.
Thanks.
JP
big-vee-twin
posted on 23/4/12 at 11:39 AM |
Think Rally Design do them
http://www.triangleltd.com
mark chandler
posted on 23/4/12 at 11:52 AM |
Get a threaded plug and 1/2" rose joint and dislocation spacers from McGill's (I'm assuming its a 1/2" UNF bolt)
Cut the rear rubber bush off the wishbone, weld in the threaded plug and bolt up
Better still do front and back, both top and bottom, you now can twiddle to your hearts content, will cost ~£40.
I know people moan about the quality of the cheap joints, I just spray mine with WD40 before and after a run, not had a problem yet but then the car
is a lot lighter, you can get better quality joints from here as well which pushes the cost up.
Regards Mark
robinj66
posted on 23/4/12 at 01:38 PM |
Mark - not quite sure I understand - any chance of piccie's
posted on 23/4/12 at 02:19 PM |
I take the full Cortina II-V subframes is used ?
Before doing major surgery check the subframe is sits horizontal and condition of subframe mounting bushes.
Also the top wishbone pivot bolt is prone to bending.
JP32
posted on 24/4/12 at 02:34 PM |
@Britishtrident:
Yes, subframe sits horizontal, mountingbushes are replaced. I didn't check the top wishbone pivot bolt. Will check this weekend.
@big-vee-twin
I will contact Rally Design if they deliver Cortina replacement wishbones.
robinj66
posted on 26/4/12 at 11:38 AM |
If it's a Pilgrim Sumo it doesn't use the Cortina subframe. The upper and lower Cortina wishbones are attached directly to the Pilgrim
chassis.
JP32
posted on 1/6/12 at 07:00 PM |
The Pilgrim wishbone's are indeed directly attached to the Pilgrim chassis. I found on the Rallydesign wishbones that are suitable for the
Locost design. Is that the same as the Cortina design?
Anyone knows?
Thanks, JP
JP32
posted on 28/6/12 at 08:19 PM |
Nobody?
JP32
posted on 23/8/12 at 07:54 AM |
Bump
