Author: Subject: 4age advice, just dreaming!
bi22le
posted on 23/4/12 at 05:45 PM Reply With Quote
Hi all,
I need to push the current set up to the limits before I go for more power but I am just checking \ thinking ahead as my brain wont stop asking questions and just let the subject sleep!! I have asked the below on both club 4ag and driftworks but there seems to be very little activity on this.
So, I have a Blacktop 20V which I would like to keep and I would like to super charge it with an Eaton M45. Rotrex are too much money and boost for what I need. I will remount the alturnator and manufacture all parts required, I like the challange. Its the engine build I need to check and expected power with reliability.
I am hoping that just a set of 4agze pistons and rods will lower the comp and add the strength. Probably 4agze injectors to get the fuel up. I am hoping thats it for the engine.
Does anybody know what power the blacktop can take with the above set up? I would like around 220. No idea of boost levels 8psi?
I dont really want to contact RAW as Im not going to buy anything at the mo so dont want to waste their time with empty questions.
I am just fishing for info. I have googled the subject to death, im sure!!
Thanks in advance.
Oh finally, anybody know the external dimensions of the Eaton M45?
Biz
Please read my ring story:
jacko
posted on 23/4/12 at 06:21 PM Reply With Quote
http://www.capa.com.au/eaton_m45data.htm
will this help
Jacko
Werner Van Loock
posted on 23/4/12 at 06:33 PM Reply With Quote
Why not just buy a AGZE and modify that? Using agze pistons won't work as it doesn't have the valve cutouts for the 5 valves/piston. So you will need custom pistons if you want to lower CR. Or need some thick head gasket/spacer.
Some good readup: http://www.billzilla.org/4agmods.htm
Some more readup: http://www.4age.net/tech/4agte_part1/index.htm
And even more: http://www.ae82.net/showthread.php?491-4age-4agze-info
[Edited on 23/4/12 by Werner Van Loock]
http://www.clubstylus.be
R1_striker
posted on 23/4/12 at 06:58 PM Reply With Quote
why not just buy a the brackets off raw and try to find a second hand rotrex. At least that all fits under the striker bonnet. Saw a striker at a track day that had a blacktop/silvertop engine mash up running a rotrex some forged bits and that was a safe 260bhp with room for lots more.
bi22le
posted on 23/4/12 at 07:00 PM Reply With Quote
I wanted to stay away from the AGZE because I wanted something different but supercharging a AGZE is a good point.
I have heard that cutouts are needed for the 20V on some sites but not required on others. I cant just use a thicker head gasket because the pistons and rods are too weak, means I would still have to change them for AGZE anyway.
Ill have a read of your links.
Whats your experience on boost and expected power?
bi22le
posted on 23/4/12 at 07:03 PM Reply With Quote
Its a lot of monies!!
A second hand Rotrex + rebuild would be the cost I expect the whole rebuild to cost. I may still use a RAW bracket because the alturnator needs remounting and a belt is still required.
260 is more than my target. That means HD gear box and HD diff, plus much more. I wanted to stay with the running gear for now.
ian locostzx9rc2
posted on 23/4/12 at 07:34 PM Reply With Quote
Speak to Dopdog on this forum he has a supercharged toyota 20v engine i think its about 270 -280 bhp
Dopdog
posted on 7/6/12 at 07:25 PM Reply With Quote
I do I do. I was going to say go for the big power and just drive it slowly!!! if you can
