Daddylonglegs
posted on 26/4/12 at 09:53 AM |
Exhaust (Again)
Following on from my thread regarding connecting an R1 can to a 1.75" (45mm) downpipe, I think my best bet is to go with the eBay shop who make
to order reducers (thanks Adrian ). The only decision is do I go for a clamp-on type or weld? I have never tried MIG welding stainless but it
appears that as long as you use the correct wire/gas it's not difficult, but the thing is I have to go and buy a reel of stainless wire which
will probably get used once every blue moon. The down side of a clamp-on type is that it looks a lot less neat.
What's the concensus of the collective?
JB
theduck
posted on 26/4/12 at 10:09 AM |
Clamp is more flexible long term, I'll be using a clamp on mine but my reduction is so small i could almost get away with a normal clamp.
Out of interest have you a link to the ebay shop you are lookng to buy from?
twybrow
posted on 26/4/12 at 10:10 AM |
It is bloody difficult to get a good, air tight finish. You have to weld ina series of spots, as SS distorts a lot during welding. Plus, you have to
turn the power and wire speed right up on your welder to get a decent weld. Personally, I was faced with this dilemma last week - I opted to takit
with my MIG, and then hand it to a pro to TIG it all together. Last time I fully welded a zorrst with my MIG, it took 3 weeks of welding and
frinding, and I stillopted to have a TIG run over it to claen it up and make it air tight!
Daddylonglegs
posted on 26/4/12 at 10:18 AM |
Yep:
Clamp
on
Weld on
Thanks for the input guys
PAUL FISHER
posted on 26/4/12 at 12:06 PM |
Ive Just fitted a carbon can on my Aries, gone from 2" to 2.5", I could have got it welded on, but when for clamps, looks good I think,
also with the clamp on you can return it back to stock if required, I used these Mikalor clamps though for a better look.
W2 MIKALOR Stainless Supra Heavy Duty Hose Clamp Exhaust Pipe Turbo Clamps Norma | eBay
