nige
| posted on 29/4/12 at 03:14 PM |
blade carbs questions
can some one please tell me what the pipe between the two pairs of carbs is for ?
and the one over the top that comes down to the right of pic
[img]http://
[/img]
cheers nige
[Edited on 29/4/12 by nige]
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
jacko
| posted on 29/4/12 at 03:29 PM |
If there off the engine blow down the mid bottom pipe then turn the carbs over if you cant blow then its the fuel in pipe and the top pipes are
breather pipe
that's how it is on zx9r carbs
this is only a guess
there the same as mine
Jacko
PAUL FISHER
They are just vent breather pipes, they just go into the airbox on the bike.
jacko
| posted on 29/4/12 at 03:55 PM |
Paul what about the bottom pipe in the middle
Graham
PAUL FISHER
| posted on 29/4/12 at 04:05 PM |
The pipes between the carbs that comes from the right are vent pipes, the middle one is the vent breather pipe.
Just to add, ive just fitted a pipercross to my fireblade, and just left these open to atmosphere, but you could get some little filters to fit on
them
mad-butcher
| posted on 29/4/12 at 07:06 PM |
on my blade top is vent, bottom one between carbs is fuel feed
nige
| posted on 29/4/12 at 07:34 PM |
Mad butcher
what is the large one between the two pair of
carbs , its like a " t " piece for?
Can i pipe them jnto the air box im making ?
jacko
| posted on 29/4/12 at 07:54 PM |
fuel in is the bottom one
[Edited on 29/4/12 by jacko]
nige
| posted on 30/4/12 at 08:19 AM |
i know the fuel is the bottom , and the top one that drops down to the right is vent
what is the one between the two pair of carbs ?
PAUL FISHER
| posted on 30/4/12 at 01:01 PM |
As already said, its just a breather vent pipe, goes to the bottom of the airfilter on the bike, you can just leave as is, or fit a little breather
filter on it, or pipe it into the airbox your making
nige
| posted on 30/4/12 at 01:20 PM |
got that now
many thanks
brookie
| posted on 30/4/12 at 05:02 PM |
quote: Originally posted by nige
got that now
many thanks
just take them all off i did and it still runs fine
PAUL FISHER
| posted on 30/4/12 at 07:40 PM |
got that now
many thanks
Just a point worth mentioning, leave the top vent pipes in place, although they can be just left to vent, they are the float bowl overflow pipes, so
if a float bowl sticks you don't want fuel allover the engine, so just leave the pipes to vent down the side of the engine towards the
floor
nige
| posted on 30/4/12 at 07:49 PM |
Ok will do thanks
nige
