hypersonic
posted on 1/5/12 at 04:04 PM |
aldon dizzy help
I`m after some help I have a 103fxs aldon distributor for my crossflow and upto now was running fine but now has suddenly started running really
poor and wont rev past 2000 rpm. The spark on the plugs is really poor. At first I thought it was the coil so tried my old coil but it was just the
same. After alot of swearing I noticed the the carbon tip that goes onto the rotor arm from the cap apears to be broken ie not cylindrical at the
end. If anyone has a cap the same could you check to see if yours is the same. Any help will be greatly appreciated.
Matt
mookaloid
posted on 1/5/12 at 05:01 PM |
it should look like this:
edit: if it doesn't then yours is probably broken (obviously this isn't the same dizzy cap as yours but the carbon brush should look just
the same)
[Edited on 1/5/12 by mookaloid]
hypersonic
posted on 1/5/12 at 05:37 PM |
Thats brilliant thanks for the fast reply. Yes mine is broken then. Best get one ordered
jollygreengiant
posted on 1/5/12 at 06:10 PM |
Get a new rotor arm as well while you are at it, quite often they will have a resistor in them to meet modern regulations (suppression) and you have
to ask, 'what has caused this cap brush to fail?'.
Just my 2p's worth.
