Author: Subject: crossflow bcf2 cam timing
johnemms
posted on 4/5/12 at 05:33 PM Reply With Quote
I got a BCF2 FAST ROAD cam in my crossflow:
SPEC : in: 37/73 ex: 73/37. FULL LIFT: 9.65 mm DUR. 290deg. 2,500-6,000
Am I right in setting my static at 18- to 20- degrees of initial timing
cheers
Jon
Typically, they recommend 10- to 12-degrees of initial timing when
the duration of the camshaft is less than 220-degrees @ 0.050” of valve lift;
14- to 16-degrees of initial
timing with a camshaft duration of less than 240-degrees @ 0.050”; and
18- to 20-degrees of initial timing
when the camshaft duration is less than 260-degrees @ 0.050” of valve lift.
