Author: Subject: Fuel tank connections????????
Irony
posted on 10/5/12 at 12:21 PM Reply With Quote
Can someone please help me with my crazy fuel tank and it's numerous connections. Please see the picture.
I know I need some sort of one way air breather valve but which of the many connections do I use?
Outlets A B D and E are about 13mm across and C is 5mm.
The fuel filler nozzle cam with the kit and works perfectly - it's just the other connections I am confused about.
[Edited on 10/5/12 by Irony]
tegwin
posted on 10/5/12 at 12:31 PM Reply With Quote
Guessing here...
E is fuel return from fuel-rail
C is filler overflow (routed to the floor)
D is the tank breather and should be connected to A
B is the top "open" end of the breather.
www.verticalhorizonsmedia.tv
Irony
posted on 10/5/12 at 12:35 PM Reply With Quote
I am running carbs so that will mean E can be just blanked off?
tegwin
posted on 10/5/12 at 12:36 PM Reply With Quote
Yes, but if you think you might be running EFI in the future I would run an extra pipe from tank to engine bay anyway!
{Some carbs have an overflow that should be routed back to the tank anyway}
[Edited on 10/5/12 by tegwin]
Irony
posted on 10/5/12 at 09:31 PM Reply With Quote
Thanks for the replies Tegwin.
Nobody else have any other thoughts?
