dave r
posted on 12/5/12 at 11:28 AM |
fuel regulator connections
![](/galpreviews/fuelreg..jpg) ![Description](/gallery/fuelreg..jpg) Description
anyone know for certain what goes where? weber alpha regulator
cant find the info on the web, and have misplaced the bit of paper....
99% certain that the top connection is left open
dave
[Edited on 12/5/12 by dave r]
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
tasmod
posted on 12/5/12 at 03:53 PM |
A is vacuum inlet from intake manifold
B is fuel outlet
C is fuel inlet
Rob
dave r
posted on 12/5/12 at 09:09 PM |
thats backwards to what i have been told by someone else......
a is manifold/ open
but other sources tell me that b is from the fuel rail, and c is return to tank...
someone else must be using one?
karlak
posted on 12/5/12 at 09:15 PM |
Not the same regulator as yours - but I should think they all work in the same way ??
see here -- (the bottom outlet is the return on this example)
http://www.tomei-p.co.jp/_2003web-catalogue/image/pic/fuel_pressure_regulator/detail_big-e.jpg
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
dave r
posted on 13/5/12 at 07:12 AM |
that makes sense....
coyoteboy
posted on 18/5/12 at 03:29 PM |
Definitely B is inlet, C is outlet.
dave r
posted on 18/5/12 at 05:44 PM |
yes you are right....
connected it that way, and tried it after i had found the instructions....
happy days maybe first engine start this weekend
dave
scudderfish
posted on 18/5/12 at 08:23 PM |
Looking at that diagram, it looks like it could work either way.
dave r
posted on 18/5/12 at 09:34 PM |
think it would.... omex paper work says c in b out a to manifold/open
garybee
posted on 18/5/12 at 10:00 PM |
To me that diagram suggests if you got it the wrong way round you'd get a massive spike in pressure on start-up due to the smaller area of
diaphragm visible to that port. I doubt that your fuel pump could overcome the force exerted by the control spring without 'seeing' the
whole diaphragm. If it did actually open then it might continue to regulate as normal, but I think it would still struggle to hold itself open in
reality.
[Edited on 18/5/12 by garybee]
coyoteboy
posted on 19/5/12 at 12:38 AM |
in at the side, out at the bottom on all of the regs I've fitted. I've made this mistake before. If you put it in the bottom the pressure
doesn't open the reg and you just stall the pump and blow hoses off.
jeffw
posted on 19/5/12 at 05:48 AM |
I have the same regulator and
A. Manifold Vacuum or open to air
B. From fuel rail
C. Return to swirl pot (or tank return depending on how you are doing it)
