xico_ze54
posted on 14/5/12 at 09:48 PM |
Sierra diff identification - Help needed
hi there
someone can tell me the conclusion about a Sierra differential with this identification plate:
83BG-4030-BA 004-BA or
83BG-4030-BA D04-BA
this because that was told me by email, not by my own inspection. the car that was taken for was a Sierra 2.0 DOHC and the guy says that is a LSD one.
that code corroborate that or not.
thanks in advance
Amadeu
austin man
posted on 14/5/12 at 10:00 PM |
http://www.locostbuilders.co.uk/viewthread.php?tid=85080
Chippy
posted on 14/5/12 at 10:42 PM |
Can't say that the numbers given mean anything to me, don't seem to tie up with any I am aware of. The 2 ltr DOHC two wheel drive, I
believe was fitted with the 3.92 diff, and I don't think it was an LSD, there was a four wheel drive 2 ltr which I believe was fitted with an
LSD, but don't know what tthe ratio was. HTH Ray
minitici
posted on 15/5/12 at 07:37 AM |
quote: Originally posted by xico_ze54
hi there
83BG-4030-BA D04-BA
thanks in advance
Amadeu
Those numbers are the casting numbers for the rear cover on the differential - you can't tell anything about the type or ratio of the
differential from that.
The differential would have s small metal tag attached to one of the bolts holding on the rear cover - from that the ratio and type can be
determined.
Failing that you would be best to get the rear cover off and the ratio is usually painted onto the crownwheel and you can see if the unit is an LSD or
open differential.
xico_ze54
posted on 15/5/12 at 09:54 AM |
I said the guy who has the diff that the numbers were in a aluminum tag bolted on top of rear cover, but I see he couldn't catch it.
thank you again for trying to help.
petew
posted on 26/6/13 at 08:35 PM |
Got a diff the same number ratio is 3.43 my problem is the standard diff oil seals do not fit standard is 62-43-12 but you check it is about 55mm
nobody can tell me were this came from
