Padstar
posted on 15/5/12 at 06:00 PM |
DIY Gearbox refurb
Is this a good idea or is it best left to the pros? I want a fully refurbished box not just a cleaned down used unit. They don't seem that
expensive to buy refurbished by professionals, but where is the fun in that.
Is any specialist equipment required to get one looking spiffing in my own garage and is there a manual that gives instructions on how to go about it
anywhere (or good websites)?
Oddified
posted on 15/5/12 at 06:21 PM |
With a bit of common sense and a methodical approach, it's fairly straight forward. A workshop manual can help though. I'm a bit like
you...why pay for someone else to do it you can do it yourself!.
Which box are you looking rebuilding?.
Ian
Padstar
posted on 15/5/12 at 06:37 PM |
Type 9 or an MT75 to suit a ford engine build. Are there manuals specifically for refurbishing gear boxes?
Oddified
posted on 15/5/12 at 06:48 PM |
An old Haynes manual for the 2.8 capri, sierra etc covers the type 9, and they're pretty straight forward. The only odd thing you need is a 36mm
socket to get the 5th gear nut off the layshaft, and that's a bit bigger than most socket sets go up to.
Can't comment on the mt75 as i haven't pulled one in bits, but gearboxes aren't rocket science!.
Ian
John P
posted on 15/5/12 at 06:58 PM |
I've not checked this thoroughly but when I got my MT75 I did do some research and it looked as though refurbishing it at home isn't
feasible. (I believe the Haynes manual also states this as special equipment is required though how special I don't know).
theconrodkid
posted on 15/5/12 at 08:00 PM |
type 9 are quite simple,the MT75 need a few special tools that aint cheap
who cares who wins
pass the pork pies
Chippy
posted on 15/5/12 at 09:55 PM |
The Type 9 rebuild is covered extensively in the Haynes gearbox book, (AUTOMOTIVE GEARBOX OVERHAUL MANUAL), (along with several other boxes). The MT75
though is not covered, although it is quite possable to rebuild them. You do need some "special" tools, but if you are a bit handy you can
infact make them yourself. There is a rebuild an MT75 post on the "Ford Power" forum which is easy to follow, plus it shows how to get
over the "special" tools needed, as well as how to fit a better ratio first gear. HTH Ray
