Author: Subject: Gear box seals - replacement
ditchlewis
posted on 17/5/12 at 07:16 AM Reply With Quote
Following my trip to stoneleigh and the bad rattle that i developed, the engine and gear box will be removed this weekend.
now i'm sure it was something silly like the thrust bearing comming off the fork, but when the gearbox is out of the car i'm going to replace the seals as has been leaking a bit (due to the breather being blocked).
my question is how do you get the old seals out? do i just just a screw driver or is there a special tool?
to pit the new ones in do i just soak the seals in gear oil and knock into place with a tube over the shaft to ensure the pressure is applied uniformally around the seal.
your advice is as always much apreciated.
Ditch
Chippy
posted on 17/5/12 at 10:32 AM Reply With Quote
This is what you need, although you can make your own, but at that price who would, HTH Ray
DRAPER O RING AND SEAL PULLER 37439 OIL & GREASE SEAL REMOVER | eBay
ditchlewis
posted on 17/5/12 at 12:01 PM Reply With Quote
many thanks will get one today
ditch
