ChrisJ15
| posted on 20/5/12 at 02:11 PM |
Duratec Cooling
Ive been hunting around on the web to look for the correct for my (ST15) Duratec.
Ive seen some suggestions but I cant see anything including the oil cooler (heat exchanger) that the ST150 has.
I'd like to keep this but cant see where I should connect it in the cooling circuit.
Has anyone used a Duratec and kept the oil cooler connected?
big-vee-twin
| posted on 20/5/12 at 03:52 PM |
If you are putting the engine into a Seven it will hang too low, you need to get a new housing and turn it through 90 degrees.
However, here's a picture of mine before I stripped it down, it connects to the thermostat housing by a tee piece, the other end feeds the
heater circuit.
The other side of the tee connects to the header tank.
[img]
  Engine
[/img]
http://www.triangleltd.com
MkIndy7
| posted on 20/5/12 at 04:48 PM |
heater circuit.
Ours fitted in an MK in the original position, kept the oil cooler and just fitted a smaller oil filter Renault 5? Quite popular and often mentioned
on here.
clearance was tight to a chassis rail underneath but you can easily unbolt the whole oil filter block off the engine and change it that way.. A small
inconvienince once a year compared to shelling out for the filter relocation kits.
Can't remember the plumbing exactly but it's treated like a Heater matrix and kept the bypass side Of the thermostat i.e constantly
circulating.
[Edited on 20/5/12 by MkIndy7]
big-vee-twin
| posted on 20/5/12 at 05:27 PM |
Think I'd rather spend the £100 rather than have a reduced capacity filter.
ChrisJ15
| posted on 20/5/12 at 06:27 PM |
The filter isnt the problem.
Its a rear engined car and the filter isnt the lowest part of the engine so Ill be staying with a standard filter.
Just not sure about the plumbing!
big-vee-twin
| posted on 20/5/12 at 07:34 PM |
Did say if you are installing into a Seven, you are obviously not, however my first post and pic answer your original query. The oil cooler was only
installed to warm the car up quicker and reduce emissions
