emwmarine
posted on 26/5/12 at 01:08 PM |
Zetec 1.8 flywheel.
Soon, I'll be turning my attention to the engine on my Dax Rush build.
The standard 2.0l flywheel is a bit of a monster and I can either buy a lightened steel one (lots of readies) or in locost style people recommend
fitting the 1.8 l zetec flywheel.
However, which one?
Is this the right one? ebay item 280878742314
There seem to be a confusing array of zetec 1.8 flywheels, some say they are dual mass others don't mention it.
If anyone knows the full story on zetec flywheels it will be very handy.
I am going to have a short at shortening the sump myself having looked at some links to very helpful zetec links.
Thanks in advance
Brian
Building a Dax Rush.
posted on 26/5/12 at 02:00 PM |
Hard to tell if thats the right one, need to see the other side!
posted on 26/5/12 at 02:58 PM |
Not sure if the Zetec ever had a dual mass flywheel, if they have I've never seen one?
emwmarine
posted on 26/5/12 at 06:22 PM |
You see this is what confuses me.
DUAL MASS FLYWHEEL & CLUTCH FORD MONDEO ZETEC 1.8i 2000-2007 MK3 | eBay
This one says dual mass flywheel. Apparently a flywheel from a 1.8 zetec is lighter than a 2.0 l. But are there different ones? If there are I will
get the wrong one.
I bought 2 Polo radiators before getting the right one.
Xtreme Kermit
posted on 26/5/12 at 06:43 PM |
It's not a dual mass flywheel on a focus mk1
I would get a focus clutch not a mondeo dual mass one.
emwmarine
posted on 26/5/12 at 07:00 PM |
Just bought the zetec 1.8 focus one.
Dusty
posted on 26/5/12 at 08:07 PM |
280878742314 looks like the right one, proper zetec blacktop one.
Dual mass is duratec engine. 1.4 and 1.6 zetec engines are sigma engines.
Alfa145
posted on 26/5/12 at 09:05 PM |
What is the weight of the 1.8 flywheel compared to the 2.0?
emwmarine
posted on 26/5/12 at 09:08 PM |
It is meant to be about 1.5 kg less. 8 kg instead of around 9.5kg.
Macbeast
posted on 27/5/12 at 06:31 AM |
I just had clutch done on 53 Focus 1.8 Zetec. Garage said nobody knows whether dual mass or not until gearbox off. Happily, it turned out not to be
dual mass.
posted on 27/5/12 at 07:15 AM |
Some zetecs did come with a dual mass flywheel in the Focus.. got one lying in the garage...
emwmarine
posted on 27/5/12 at 09:53 AM |
Knowing my luck I will have bought a dual mass one.
Xtreme Kermit
posted on 27/5/12 at 11:34 AM |
Fingers crossed its the right one as I bought one from the same people a couple of weeks ago...
