shedman
posted on 27/5/12 at 12:08 PM |
Zx6r carbs on 1300 ford crossflow
Hi I have just fitted zx6r carbs to my crossflow .an just fired the engine up this morning but runs very rough the only thing i have done screwed the
idle jets in an out 2/half turns this has helped still to balance them up as well . Has anyone ever done this on a crossflow it was just to some idea
of main jets sizes any information on this would be very welcome cause I haven't a clue . Thanks
whitestu
posted on 27/5/12 at 03:58 PM |
I have ZX6Rs on my Zetec 2.0 with 1.6mm mains.
Stu
shedman
posted on 27/5/12 at 05:09 PM |
Bike carbs
Cheers stu seems a lot of you guys are running 1.6 jet sizes or anything from 1.3 to 1.7 /. 1.6 being the norm . The jets that are in just know
outside ones are 1.4 the two insides are 1.5. So I was going to start there. Do you know how to check for lean fuel is it a case of checking the plug
colour. Thanks for the reply.
jacko
posted on 27/5/12 at 06:27 PM |
The only safe way is to get it set up on a rolling road
I would start with 1.5 jets and work up
After drilling the jets get the carbs balanced and go from there
Jacko
posted on 27/5/12 at 07:43 PM |
If its running rough the carbs probably need balancing. When mine are out of balance my zetec runs really rough, hunting and barking...
whitestu
posted on 28/5/12 at 08:12 AM |
Do you know how to check for lean fuel is it a case of checking the plug colour
As Jacko said a rolling road is best, however mine were done at home using a wideband AFR meter.
Stu
deezee
posted on 28/5/12 at 09:36 AM |
You are going to struggle tuning an engine, with a set of motorbike carbs, without any diagnostics available to you at all! There is no default jet
size, needle position or idle mixture for any given engine. Everyone has a different air filter, exhaust and manifolds. I had to put a wideband on
my car to get it running and then drive it, and tune it as I went.
shedman
posted on 29/5/12 at 12:09 AM |
Carbs
Thanks guys all the info has been taken onboard .will have a go an let you know.
