itsawindupuk
posted on 31/5/12 at 09:33 PM |
type 9 rebuild woes
hi everyone, i rebuilt my type 9 using a bgh hd leshaft and leygear, i was really happy with it and the fact i managed to build a gearbox myself.
Unfortunately ive had to disassemble it as i need to change the input shaft from my previous broken box. To remove the inout shaft you need to drop
the leyshaft but with the new HD bearing you cannot remove the leyshaft as it has a pressed on sleeve, Ive spent all evening today and yesterday
trying to drop it, but i cant. An ideas?
Adam
mcerd1
posted on 1/6/12 at 11:53 AM |
have you tried calling the guys at BGH, they are normaly very helpful
Gary 7
posted on 1/6/12 at 03:28 PM |
If the layshaft has the pressed on hd bearing sleeve, you need a press to remove it , if it wont shift with a hammer and drift.
itsawindupuk
posted on 2/6/12 at 07:07 AM |
called bgh, i didnt realise i had to remove the large lower roller bearing. took it out and the laygear dropped ![](/images//smilies/smile.gif)
