nilocp
posted on 1/6/12 at 06:12 PM |
Crossflow sump
Anyone got pictures or drawings of a modified crossflow sump, that will increase ground clearance and not reduce capacity?
Colin
Westy1994
posted on 1/6/12 at 06:44 PM |
Mine as modded last week. Capacity as per the standard sump.
[/url]
Clearance with it fitted, now level with the bellhousing.
[/URL][/url]
If this is what you are after, I will get the tape measure out for you.
Rich
nilocp
posted on 1/6/12 at 07:05 PM |
Hi Rich, I see where you are coming from. No need for a tape measure.
What did you do with baffles?
Colin
Westy1994
posted on 1/6/12 at 07:11 PM |
Hi Colin,
it uses all the baffles that were fitted to the sump as standard and left in the same place, we did add a small one within the lowered section as
well, although with the wings built as they are, not much surge should happen.
I have the measurements now , as I had to check something else anyway just before.
Let me know if you need them.
Rich
