Author: Subject: Sump replacement advise.
sky12042
posted on 2/6/12 at 08:20 PM Reply With Quote
I'm replacing my sump on the red top with a low line sump, so I need to remove the pick up pipe, now question is when I refit the new pipe It will be empty.
So do I
1 hand crank it a little to get some oil up the pipe
2 take the ht leads of the plugs and crank it over abit
3 it will be fine, so start as normal
I do have a oil warning light but not pressure gauge
Any advice welcome.
Andy.
JAG
posted on 2/6/12 at 08:30 PM Reply With Quote
Once you've rebuilt the engine take the plugs out and spin the engine on the starter until you see some oil pressure or the light goes out.
Then put the plugs back in and start as usual - I did this with my engine after a sump and pick-up pipe change and it's done 9000+ miles since
[Edited on 2/6/12 by JAG]
Justin
sky12042
posted on 2/6/12 at 10:03 PM Reply With Quote
Cheers mate.
I'll try that tomorrow.
Andy.
stevegough
posted on 3/6/12 at 06:33 AM Reply With Quote
What are you using for the sump? The standard C20XE (alloy) one or a 8v steel one? I have the latter, and even shortened I still only get 2 and a half inches of ground clearance!
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
sky12042
posted on 3/6/12 at 08:50 AM Reply With Quote
Currently have 8v steel one with about 2" clearance, got hold of a 2nd hand zukspeed manta type sump. So should gain an extra inch or so.
stevegough
posted on 3/6/12 at 02:36 PM Reply With Quote
Do you mean YUKspeed? The winged Manta sump is supposed to be a good way forward - just a bit rare and expensive. Let me know what ground clearance you get with it on?
Luego Locost C20XE.
sky12042
posted on 3/6/12 at 03:38 PM Reply With Quote
Yeah sorry yuk, typo. Was going to fit today but the rain has put me off, so will try again tomorrow. And will let you know what clearance I get.
Andy.
