jakeob
| posted on 29/6/12 at 08:49 PM |
What a dick i am!!
If you could have seen in my garage about an hour ago you would have seen a fifteen stone dick head jumping up and down on a 4 foot socket extention
bar.
I have just tried to undo my rear wheel hub the wrong bloody way, and threaded my drive shaft
All this to convert to disks
Ohhh bugger
PSpirine
| posted on 29/6/12 at 09:04 PM |
Surely you're changing the shaft/joint for the disc bolt-on ones? So it's only the old ones you buggered?
If it helps I did that for about 2 days when I had my mini until I realised.
jakeob
| posted on 29/6/12 at 09:30 PM |
No I am using the same push in drive shafts, i am taking the hubs off to get them machined slightly smaller so the new disks will fit over them.
RK
| posted on 29/6/12 at 09:36 PM |
every one of us has done similar things. Part of the deal. Good luck with it!
jossey
| posted on 30/6/12 at 08:27 AM |
If anyone on here says they haven't done anything stupid whilst building the kit then they are lairs lol....
David Johnson
MikeFellows
| posted on 30/6/12 at 09:31 AM |
i buggered a set of perfectly good front and rear hub and hub carriers on day 1 of the build
ive also bought stuff in preperation for stuff only to find when i get to the job ive bought the wrong bits and i cant reasonably expect to return
stuff after 6 months
I reckon all in all my stupidity has cost me between £500 - £1000
whitestu
| posted on 30/6/12 at 10:10 AM |
I changed an Alfasud gearbox to fix a mystery knocking noise once. Turned out to be the wheel studs that were loose! I was only 18 though!
Humbug
| posted on 30/6/12 at 11:05 AM |
As in "evil lairs"? mwahahahaha
| posted on 30/6/12 at 11:08 AM |
quote: Originally posted by RK
... every one of us has done similar things...
God knows I have!
It's Evolution Baby!
iank
| posted on 30/6/12 at 11:16 AM |
I'd rather be a liar than an idiot
Anonymous
jakeob
| posted on 30/6/12 at 03:01 PM |
Well after ringing around and having no luck in locating a shaft, i decided to make the 4 hour round trip to Mk,,,
They matched me up another drive shaft they said would work!!!!,, only to find its too fat to go through the big hole in the upright
Liam
| posted on 30/6/12 at 06:27 PM |
Is that just cos it has the ABS toothed ring? If so, needs turning off.
I've done the same myself but jumped on at least a 6' pole . It was when dismantling my Sierra which was a 4x4 - I'd got three hub
nuts off no problem and went on to the fourth. Broke three Halfords 2' breaker bars in the same day and they were good on the lifetime warranty
every time . Then I realised what I was doing wrong! Despite that punishment the threads were fine though.
[Edited on 30/6/12 by Liam]
jakeob
| posted on 30/6/12 at 09:22 PM |
  drive shafts
The bottom shaft is the right size and the top one is too fat,,, i dont think it can be machined down
