rash12
posted on 30/6/12 at 08:20 PM |
pinto timing
cn anyone tell me the pinto timing settings its a 2.0 on bike carbs if that makes any difference ?
thanks in advance
Hector.Brocklebank
posted on 30/6/12 at 08:47 PM |
Dot on crank pointing straight up (tdc) marks should line up with a mark on the block
Dot/Pointer on cam straight down, again marks will line up with a mark on the head
Rotor arm on distributor to be pointed to a line marked on the dizzy body
the pinto is as simple as it gets....
[Edited on 30/6/2012 by Hector.Brocklebank]
Some people can never handle the truth and always try to shoot the messenger instead of taking an honest look in the mirror (its always easier to
blame another than to face reality), but secretly they wish they could grow a pair and be the messenger !!!
rash12
posted on 30/6/12 at 09:01 PM |
sorry i meant using a stobe light
thanks
snapper
posted on 30/6/12 at 09:29 PM |
Standard cam unleaded about 8 degrees
Performance cam manufacturers setting usualy 10 to 12 depending
36 to 38 degrees all in at 3600rpm
I eat to survive
I drink to forget
rash12
posted on 30/6/12 at 09:35 PM |
thanks snapper will set tmos to 8 degrees btdc
