mcg
posted on 16/7/12 at 03:35 PM |
Measure C02 at home
Hi- appologies if this has been covered a million times before, but I am struggling to find anything on it:
I would like to measure C02 for IVA emmisions prep at home. Is it possible to use my AEM Wideband AFR Lambda UEGO Gauge to do this?
Otherwise, how can I do it bar taking it down the local MOT station?
Thanks in advance.
Matt
posted on 16/7/12 at 04:29 PM |
An oxygen sensor can't measure CO2.
steve m
posted on 16/7/12 at 04:42 PM |
well one way would be... , but it is flawed,
inhale all the exhust fumes, if your still alive after 2 mins, it will be fine
PLEASE DONT DO THIS!!
matt_claydon
posted on 16/7/12 at 05:34 PM |
It's CO, not CO2, which is tested at IVA by the way.
Rod Ends
posted on 16/7/12 at 08:58 PM |
Gunson G4125 Gastester Digital
mcg
posted on 16/7/12 at 08:59 PM |
okeydokie...cheers for the reply's.
Is there a way of doing it at home then?
matt_gsxr
posted on 16/7/12 at 09:37 PM |
You can't measure CO, or CO2 with a lambda probe, but you should be able to get the mixture correct with a lambda probe, which should give you
the correct CO2 and CO.
