Mr Whippy
posted on 18/7/12 at 12:30 PM |
what direction do shoguns turn?
Hi
Any one know which direction a shogun mk 2 diesel engine rotates? It’s because I want to fit a shogun power steering pump in my old landy and just
want to check it turns the same direction
Wonder how often engines do rotate different directions or are they all a standard direction??? never thought about it tbh
JeffHs
posted on 18/7/12 at 01:06 PM |
I've never seen a car engine that rotates differently, but American aero engines rotate in the opposite direction to ours.
deezee
posted on 18/7/12 at 01:17 PM |
Well rather famously Honda engines used to turn the 'wrong way' until recently. Hence the reason the older Honda engines are never used
in kitcars.
loggyboy
posted on 18/7/12 at 01:22 PM |
in kitcars.
yeah, my old Triumph Acclaim (aka Honda Ballade) had one of those. Pretty rare TBH
Mistral Motorsport
Mr Whippy
posted on 18/7/12 at 01:34 PM |
ah so I can then assume it will be turning the same way, ok
we'll see
cheers
reminds me of that psot where the guy thought his engine goes backwards when the cars put in reverse, oh that was so funny
posted on 18/7/12 at 01:37 PM |
Mine went the same way, so you've know problems.
minitici
posted on 18/7/12 at 01:52 PM |
Some two stroke microcars did run the engine backwards so that they could reverse!
Mr Whippy
posted on 18/7/12 at 02:09 PM |
nice thanks I've just ordered the pump, not many these days use a v-belt
many of my model plane engines would often run backwards when started but with much reduced performance
Slater
posted on 18/7/12 at 02:12 PM |
The Dolphin Yacht Auxiliary engine does this, i.e. in order to go backwards you have to stop the engine and start it in reverse.
The engine was originally designed as an air cooled unit for use in the small Berkeley 3 wheeler car and later in a motor cycle scrambles machine
It was designed by Colin Chapmans brother, a Mr David Chapman !!!!!!!!!!!!!!!
More info here
Agriv8
posted on 18/7/12 at 02:56 PM |
as a turse reply
I was going to add in Bradford Anyway it wants and ussually without any indicators or regard for other road users .
ATB Agriv8
