r1_pete
posted on 18/7/12 at 07:02 PM |
Megajolt mapping logic check
I just want to check my logic, I'm mapping the megajolt on my 4.2 jaguar engine, starting from scratch as there is nothing out there to
clone.
I have taken the initial and centrefugal advance curve from the stock distributor, and mapped that to the maximum load, figuring that regardless of
load, RPM is RPM and the centrefugal advance will behave the same whatever the load.
I then added the vacuum advance to the initial and centrefugal advance, and used that for the minimum load curve.
Finally creating the values in between to create a smooth 3d map.
I know it will need some tweaks, but can anyone see any faults in the logic? all other mjlj maps I've used I have started with a downloaded map
from a similar spec engine.
Cheers.
Pete.
John P
posted on 18/7/12 at 07:22 PM |
Can't comment on your logic but I did find this on line:
http://dl.dropbox.com/u/8496016/S1%204.2LVacuumStock.zip
It's supposedly a map for a Jaguar engine. I don't have anything to open it but you may want to check it out.
John.
posted on 18/7/12 at 11:05 PM |
No logic faults, this should get you up and running to a reasonable level pretty quickly. However you will effectively be configuring your Megajolt
to emulate the inherently compromised timing that a mechanical distributor limits you to.
Nickp
posted on 19/7/12 at 06:37 AM |
I'm going to do the same when I MJ the twin cam my Montecarlo, but mine's even simpler with no vac advance. This will give me a base map
to get me to the rollers, which can then be tweaked to get the best out of it.
