Author: Subject: Clutch for 1.8 zetec to MT75 gearbox?
Matt_C
posted on 18/7/12 at 07:51 PM Reply With Quote
Hi, I have been reading quite a few posts on here about which clutch to use for a 1994 1.8 Zectec mated to an MT75 gearbox and I am getting a little confused on what exactly I need. Advice is needed from the collective.
I have read people recommending the 1.8 clutch or 2L clutch and that the flywheel should be replaced if using the 2L. I would prefer to not spend too much, so not to change the flywheel but need to make sure I have the correct combination for the job.
I also understand I need the MT75 clutch arm pin I have seen on the kitspars/GBS website. Is there any other parts I would require to mate the engine and gearbox?
Many thanks for all your help and advice,
Matt
big_wasa
posted on 18/7/12 at 09:04 PM Reply With Quote
You need a clutch from a 1.8 zetec that was fitted with the mtx75 gearbox as this will have a 220mm clutch with a 1" 23 spline drive clutch plate.
The thrust bearing is a long way away from the clutch cover.
options...
Westfield use a spacer on a new bearing.....= very dear
Gbs do the pin for a few quid.
You can drift the old pin out and tap the hole and fit a nut and bolt giving adjustmant
Westfield's bearing was the way to do it years ago but I would use the pin from Gbs if I was doing it again, or my version of .
[Edited on 18/7/12 by big_wasa]
