Author: Subject: X-flow compression update and help please!!!
Nickctp
posted on 17/8/12 at 11:11 PM Reply With Quote
Hi all,
further to my recent post here about low compression and a variant in compression between cylinders I decided to take the head off and look a little deeper. Well the valve stems are worn (lots of play) and they could also do with re lapping but I think my main problem is the bores there is a lot of movement in the pistons (far to much) and the bores are very shiny (no lips though). The problem is they have already been rebored to .90 so thinking the bores will need lining??
As I previously mentioned I just couldn't get the engine running right & couldn't tune the carbs etc, I think the above is the problem - would you agree?
Basically I'm just after knowing what route to go down here. I have a good competition head, (needs valves sorting), fast cam , twin 40s - all the right bits, but problems with the bottom end. Do I either - have the bottom end rebuilt and do the rest of work myself or will it be better to buy a recon block & pistons etc.
I am fully aware that this will cost, but I am looking for the cheapest route to go down here as its not the right time to be throwing money about right now.
I am fully capable of stripping and rebuilding an engine but when it comes down to it - I don't really know much and neither do I claim to so all advice would be very much appreciated.
Look forward to your comments.
Nick
[Edited on 17/8/12 by Nickctp]
maccmike
posted on 17/8/12 at 11:19 PM Reply With Quote
As your capable of doing the work I would price up std bits, uprated bits and a new bottom end. Then decide whats best. Besides, theres no guarantee a 2nd bottom end will be a good'n.
Westy1994
posted on 18/8/12 at 01:18 AM Reply With Quote
If that were my engine, I would be looking at a decently priced secondhand block, or full engine if it were cheap enough. Then rebore as needed, but NOT to max as your old block has been. Unless you are actually racing the car, I see no reason to max the bore size, but use the next bore available to make the 'new' block useable.
Given the fact that you state there are no visible 'lips' at the top of the bores, would it then be feasible to simply re-ring the pistons and rehone the bores?, this may well be the cheapest option?. Of course getting them relined as you say is yet another option as well, it really all depends on cost as mentioned above, and what sort of engine you want to build back up.
I need to carry out a similar task over winter, but I am on standard size bores still, so I am lucky in that respect.
Price up what a re-ring would cost Vs liners, I would suspect the re-ring to be cheaper as you don't need new pistons ( unless yours are damaged in some way?) and both will require a rehone anyway.
Just my 2p's worth.
Rich
Nickp
posted on 18/8/12 at 07:03 AM Reply With Quote
Too much movement on the pistons? How much, have you actually measured it (pistons and bores)? If there's on lip on the bores then they aren't worn. If you're worried about them been shiny, give them a light hone and fit new rings. You had about 200psi on all cylinders so I can't see there been a big issue with your bores / pistons. I'd sort the valve guides, re-lap and slap the head back on TBH
posted on 18/8/12 at 07:07 AM Reply With Quote
Ditch the xflo these days they are too expensive to fix, a Silver top will cost money to fit but will give more power than a modded xflo and be a lot more reliable. The big advantage is you can buy a replacement for buttons.
chillis
posted on 18/8/12 at 07:37 AM Reply With Quote
Originally posted by Nickctp
Hi all,
Get the bore and pistons measured first to see how bad and to check the pistons are the right ones for the bores! Ive seen +60's in +90 bores before. You can go slightly bigger (are yours 83.25 or 83.5mm?)
IIRC they bore to about 85mm for the liner but without checking the wall thickness you could be getting mighty thin.
Liners will only take you back to standard bore I believe though there might be some other liners that could be used to get you to the size you are now - you'd need to speak with whoever was going to do the job to see what they can get/recommend.
Nick
chillis
posted on 18/8/12 at 07:47 AM Reply With Quote
Ordinarily I'd agree with you though silvertops are all getting rather old now.
In this case the OP has a well sorted engine and all the bits that go with it - it just needs a rebuild by the sound of it or even just pistons the right size!
Rebuilding a zetec will cost pretty much the same as an xflo.
snakebelly
posted on 18/8/12 at 10:07 AM Reply With Quote
if your block is beyond it i just checked on ebay and there are a few going for not silly money.
snakebelly
posted on 18/8/12 at 10:09 AM Reply With Quote
on second thoughts dont mess around, get this:
FORD RACING BRAND NEW X-FLOW 1600 ENGINE BLOCK!! | eBay
Fatgadget
posted on 18/8/12 at 12:20 PM Reply With Quote
My goodness!..Im lost for words!!
If only i had the foresight of accumulating all those old Ford engines being thrown away back in the 70s/80s..
snakebelly
posted on 18/8/12 at 04:28 PM Reply With Quote
Complete engine going on this thread:
http://www.locostbuilders.co.uk/viewthread.php?tid=173602
Nickctp
posted on 19/8/12 at 05:52 PM Reply With Quote
A little more than I wanted to spend right now ;(
Nickctp
posted on 19/8/12 at 05:53 PM Reply With Quote
Exactly my thoughts - still not sure what to do
Nickctp
posted on 19/8/12 at 05:59 PM Reply With Quote
They wobble about in the bores like crazy - no 4 is the best if I squirt some wd down the bore it retains it for a long while - other 3 pistons just drain away instantly with no 1 being the worst. Also think I have been lied to and they are not 1300 pistons still the original 1600!! (
