Author: Subject: C20XE inlet angle
FASTdan
posted on 22/8/12 at 03:06 PM Reply With Quote
C20XE inlet angle
Can anyone tell me approximately what the angle is of the face that the inlet manifold bolts on to? iirc they are not vertical?
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
keybaud
posted on 25/8/12 at 12:09 PM Reply With Quote
I think it's 27 degrees, depending which way you measure it. This is because I had to order a 27 degree manifold for my vertically mounted C20XE, when I'd originally been given a 34 degree one (which I believe is for the engines mounted at 7 degrees).
