Author: Subject: Blacktop Broken
Daddylonglegs
posted on 22/8/12 at 09:08 PM Reply With Quote
Blacktop Broken
In between alternator issues, I thought I would get my next project engine onto the engine stand so I can clear out the garage a bit and maybe start slowtime strip-down of the engine.
It was one I got cheap (off here IIRC) and the car it came from was a water damaged write-off.
No history on it other than that. It turns over by hand but there was a 'clink' a couple of times when I turned it so time for a quick 'look see' as you do, and I noticed that #2 piston ain't doing the uppy downy thing. So I guess either the gudgeon pin holder on the piston has gone or the conrod has broken.
At least I now know that a strip down is a good idea!
I know people are going to say "just get another engine" but I'll see what transpires first and keep my eyes out for replacement internals. I am in no hurry for it anyhow so it will give me a project while I'm waiting to afford the next car
mookaloid
posted on 22/8/12 at 10:23 PM Reply With Quote
Don't forget to post some pics up when you have found out what's failed
stevebubs
posted on 22/8/12 at 10:24 PM Reply With Quote
If you're going the strip down route, it may be just as cost-effective to build something a little special...
Bluemoon
posted on 23/8/12 at 08:13 AM Reply With Quote
Sounds like someone tired to run it with water in one cylinder...
snakebelly
posted on 23/8/12 at 08:31 AM Reply With Quote
i recently picked up a free blacktop in kit form off a member here, only wanted a few bits so think i might have a set of rods if you need them, i got the engine FOC on the basis that any bits i moved on were also FOC so if you want them there yours, the workshop is in Market Drayton so not a million miles from Burton, ill be there Saturday if you wanted them. In fact ythinking about it you could have the whole bottom end.
Daddylonglegs
posted on 23/8/12 at 09:25 AM Reply With Quote
Yep, my thoughts too. Water doesn't tend to compress too well does it?
@snakebelly: u2u sent chap
[Edited on 23/8/12 by Daddylonglegs]
ChrisL
posted on 23/8/12 at 12:33 PM Reply With Quote
Tried it with a silver top and petrol, now have a blacktop. 1 bent con rod and probably a bent head...
