Author: Subject: Advice please and hopefully a answer
jacko
posted on 2/9/12 at 04:19 PM Reply With Quote
Hi all
I hope some one can come up with the right answer
When driving the indy when i lift off the throttle there is a rattle noise coming from the gearbox / clutch area
If i dip the clutch while it's making the noise the noise stops
But the gearbox /prop diff axle is still turning
What do you all think it will be causing the noise
The noise is not there while its driving under load
The engine is a pinto - type9 gearbox - sierra diff
Could it be bearings in the gearbox ?
Jacko
mookaloid
posted on 2/9/12 at 04:23 PM Reply With Quote
Hi Buddy
Is it the release bearing chattering against the clutch cover?
Try adjusting the cable a bit to take out most of the slack to see if that does the trick - it did on mine
M
renetom
posted on 2/9/12 at 04:34 PM Reply With Quote
Rattle
Hi
It the release bearing knackered
You need to fit a new one,
Putting it up against the pressure plate will stop the rattle but will shag the pressure plate if the bearing seizes.
Good luck
René
posted on 2/9/12 at 05:32 PM Reply With Quote
Have you tried adjusting the slack out of the clutch cable? IIRC someone posted about the same problem recently
jacko
posted on 2/9/12 at 05:36 PM Reply With Quote
Hi No, it looks like it will be my first job to try to stop the noise
Please keep the ideas coming just in case its not the cable adjustment
Jacko
posted on 2/9/12 at 06:26 PM Reply With Quote
ad rattle update Originally posted by ditchlewis
after the problems on my trip to stoneleigh, a bad rattle from the gear box, i have had the car out for a drive tonight
the rattle is gone, it would appear to have been the thrust bearing fork being badly adjusted and this has been cured by a capri clutch cable with built in adaptor.
the oil i used is a bit thicker than the standard spec and this has resulted in a clunky change when cold.
unfortunatley the test drive was limited to 5 miles as there is now an over heating problem. a leak some where, but it is too dark to see now.
many thanks for all the advice lads
ditch
HTH Mel
[Edited on 2/9/12 by rusty nuts]
jacko
posted on 2/9/12 at 06:42 PM Reply With Quote
ditch
HTH Mel
Rusty Nuts
Thank's for the info it looks like the cable adjustment is the first thing to look at it will be next weekend before i get time
Jacko
snapper
posted on 2/9/12 at 08:11 PM Reply With Quote
Earlier reply said thrust bearing knackered, I think not.
Thrust bearings tend to make noise when clutch depressed not when free
I also think its a simple loose cable.
I eat to survive
I drink to forget
RichardK
posted on 3/9/12 at 09:33 AM Reply With Quote
Yeh, I'd agree with the cable stretching a bit, maybe worth checking it's not fraying anywhere as I about to snap before taking the slack out?
Rich
Gallery updated 11/01/2011
jacko
posted on 3/9/12 at 04:38 PM Reply With Quote
Hi All
I have adjusted the cable tonight it was not that slack before i started
I wont get out in it until the week end to try it
Jacko
jacko
posted on 10/9/12 at 06:28 PM Reply With Quote
Hi all
I have adjusted the cable and tried the car over the weekend but it has not made any difference,
so its back to square one.
Has anyone got any other idea's what it could be before i pull the engine / box out
Jacko
