James
posted on 7/9/12 at 10:41 AM |
Alternator mount- Rascal on Pinto
Anyone able to show photos of their Rascal alt' onto Pinto mount please?
Story behind it:
Heard a bit of belt squeal the other day, had a poke around and found that the alternator mount that bolts my Bedford Rascal alternator to my Pinto
has sheared in 2!
It's a 30mm wide strip of 3mm to which I welded the the upside down U bracket ground from the Rascal's own mount.
It has sheared literally in half vertically in the middle of the strip equidistant from the 2 engine bolt holes.
I suspect I tightened the belt too much (the adjuster is perhaps a little too short!) and so the bracket was twisted slightly hence why it has split
where it did.
Easy fix is just to make another using 5mm plate or similar instead of the 3mm... but this isn't really the way I like to do things. If
there's a stronger, lightweight option I'd rather go for that.
So, just looking for some smart ideas please!
James
Pre-painted original:
[img]
Alternator- new bracket
[/img]
You can see the break:
[img]
Broken Mount
[/img]
The guilty party... the bolt has half come out!!! Wondering if this has caused it all rather than me adjusting the belt too tight!
[img]
Broken Mount
[/img]
Snapped along the HAZ!
[img]
Broken Mount
[/img]
[Edited on 7/9/12 by James]
- Muhammad Ali
mcerd1
posted on 7/9/12 at 12:31 PM |
where it did.
I've got to make my first one, so looking for ideas for mine too
got any pics of the failed one ?
James
posted on 7/9/12 at 02:19 PM |
I realised they'd have been handy as I posted... but couldn't find mine!
With the weather like this I'd like to drive this weekend so will get over to the garage this evening if poss.
James
- Muhammad Ali
