pmc_3
| posted on 23/9/12 at 07:25 PM |
Differences between p100/transit engine and normal pinto
A friend bought a spare pinto to rebuild and he tells me it turns out its a p100 engine. What are the differences between these and the regular pinto?
I presume pistons are different for the lower compressions but are the crank and head different? Cheers
[Edited on 23/9/12 by pmc_3]
snapper
| posted on 24/9/12 at 07:50 AM |
The known difference is low compression pistons, shown in the Haynes manual.
The piston top is lower down the bore.
May have a thicker flywheel.
P100 Type 9 is also different with much lower 1st gear
I eat to survive
I drink to forget
emwmarine
| posted on 24/9/12 at 08:37 AM |
I have a P100 type 9 gearbox if anyone is interested.
Building a Dax Rush.
chillis
| posted on 24/9/12 at 09:06 AM |
Commecial Pinto Vs Pass. car Pinto. Depending on engine age and size, differences range from camshaft, valves, compression ratio, pistons, sump,
flywheel, carb and manifold, exhaust manifold. In fact quite a lot.
What engine size is it?
