Craigorypeck
posted on 20/10/12 at 08:32 PM |
Flywheel and ringear location- 9 hole YB
Evening all.. When I first built my YB cossie the starter motor pinion when bolted on was always in contact with the flywheel, as a quick fix I spaced
the starter out with washers, this time around after a cracked block repair can anyone shed some light on my flywheel?? Its a cosworth 9 hole machined
down to pinto size and the ring gear put on. I bought it as is.
Heres a pic..
Does it look like it sitting too far back?? for the pinion to clear it would need to be flush with the face.
Should it be??
Ta
snapper
posted on 21/10/12 at 03:59 AM |
Looks ok to me
As I remember the ring gear sits on a locating lip
Clutch face is always proud so you can skim it if needed
I eat to survive
I drink to forget
