Benzine
| posted on 21/10/12 at 08:58 PM |
Alternative radiators?
I'm using a Polo radiator at the moment in my MK Indy. I'd like to move the radiator down a few inches but the lower outlet will foul the
chassis (as demonstrated in the below diagram with dramatic red lines)
Are there any rads that can get around this? e.g. central/offset outlet, different shaped radiator?
austin man
| posted on 21/10/12 at 09:04 PM |
an early escort one I believe MK can supply them I have one fitted no cooling problems on a Silvertop Zetec
Benzine
| posted on 21/10/12 at 09:15 PM |
Thanks for the info, would that be this type?:
This is what I originally had fitted to my MK which would have come with the kit.
steve m
| posted on 21/10/12 at 09:25 PM |
I found the early escort rad, a real pita as the bottom hose is too close the steering box/shafts
i now have a polo rad, that is slanted at about 15% to get in the available space, and allows the nosecone to fit
austin man
| posted on 21/10/12 at 09:28 PM |
no problems with the escort rad just enough clearance between the bottom hose and chasis rail
Canada EH!
| posted on 22/10/12 at 12:27 AM |
A little off the wall but a Hyundai Excel rad fits my locost very well, outlets work well with my toyota 4age.
40inches
| posted on 22/10/12 at 07:45 AM |
I used a Clio rad, fits really well, the bottom hose is at a nice angle.
big-vee-twin
| posted on 22/10/12 at 08:30 AM |
I've used a Seat Leon radiator, slightly bigger than Polo and has a thicker core.
the rad is angled by 15 degrees or so but fits very sung under the nose
http://www.triangleltd.com
Dick Axtell
| posted on 22/10/12 at 08:49 AM |
Hi Steve. Since I've just bought a Polo rad, and will be installing, (after some additional IVA-directed fettling), am very interested in your
mounting method.
But I gotta ask - 15% or 15 degrees? And if so, relative to those front upright-ish chassis rails? They are not vertical, on my chassis. I'm
guessing that this mounting angle takes the lower inlet away from the potential foul point, as in Benzine's diagram.
Ah! Just read big-vee-twin's post, immediately preceeding mine. Seems to answer the question.
[Edited on 22/10/12 by Dick Axtell]
Benzine
| posted on 22/10/12 at 08:32 PM |
Thanks all for the replies
